rancher wont move part 2
Old Dec 6, 2006 | 05:15 PM
LocknLoad's Avatar
Default rancher wont move part 2
In an earlier post I have a 2000 rancher 2wd manual (foot) shift that will no longer move, forward or reverse. I can push it no problem, so brakes are not locked up
I jacked up the back end put it in gear and the tires would move very slowly forward and reverse. adjusted the clutch and now the tires will move a lot faster with it jacked up, but if I put it back on the ground it will no longer move. I suppose this means the clutch is burnt up?
How hard is it to replace the clutch in a rancher? Dont have a service manual, thought about ordering one and doing it myself. any special tools required? Do you have to pull the motor to do it? This has the motor mounted sideways and the clutch is in front.
Old Dec 6, 2006 | 10:09 PM
LocknLoad's Avatar
on the rancher the motor is mounted sideways compared to how a normal engine is mounted. this lets the driveshaft hook directly to the transmission without having to go through another gearbox.
Old Dec 6, 2006 | 11:45 PM
LittleBill's Avatar
clutches are removable through the front motor cover, not sure which clutch is shot on your's i know my buddy needed to make a clutch puller to remove the centrifugal clutch, i would get the manual it will save you a big headache
greg74
Sep 10, 2019 03:03 PM
user493
Aug 13, 2015 12:54 PM
ghost civic
Jul 27, 2015 03:15 AM
Scottma518
Jul 16, 2015 09:19 PM
Scottma518
Jul 10, 2015 12:42 AM
