jetting for the winter?
Old Jan 21, 2007 | 10:47 PM
bombrider04's Avatar
Default jetting for the winter?
I was wondering what people would suggest for jetting for my 07 450r in the winter time...I have no performance mods currently and I also know that the Honds run lean from the factory, so my ? is how lean do they run? I haven't messed with my carb on the 450 yet but I looked online and saw that they have a 120 main in them now... should a 125 be fine to get me to run where it should in the summer and when it is warmer out and go to a 130 for the winter...I just want to get an idea so I can get me some jets and I am also at sea level. Thanks for any suggestions.
Old Jan 21, 2007 | 11:29 PM
JLsparky7's Avatar
Not all bikes run lean from the factory. It depends a lot on where you live. Altitude, humidity and temperature. You shouldnt have to worry about it on a stock quad. Maybe give you idle jet screw out 1/4-1/2 turn to make starting a little easier. Other than that you should be fine. Ive rode my shee with stock jetting for 2 years in the cold with no problems so far.
Old Jan 22, 2007 | 12:51 AM
hondabuster's Avatar
If its totally stock, you probably wont need to do anything except adjust the mixture screw, as said.
Do you have any symptoms of lean?
Such as
- Poor acceleration; the engine feels flat.
- The engine won't respond when the throttle is snapped open, but it picks up speed as the throttle is closed. (A too-large main jet also mimics this symptom.)
- The engine runs hot, knocks, pings and overheats.
- The engine surges or hunts when cruising at part-throttle.
- Popping or spitting through the carb occurs when the throttle is opened. Or popping and spitting occurs through the pipe on deceleration with a closed throttle.
- The engine runs better in warm weather, worse in cool.
- Performance gets worse when the air filter is removed.
Old Jan 22, 2007 | 11:17 AM
CamoKodiak450's Avatar
Has Been Around Here Quite Awhile!
If there was ever a quad that came from the factory LEAN, it would be the 450R.
I'd bump it up and remove the airbox cover, and it will be a different quad! I replaced my fuel screw with an adjustable one just to make small changes.
Old Jan 22, 2007 | 01:19 PM
I haven't ridden it in the winter just yet and it was in the 60's until this week...it ran fine for me when it was warm out but I heard that the 450r runs lean from the factory that's why I was wondering...I'll pull a plug when I get a chance and see
Old Jan 23, 2007 | 01:53 PM
Hey guys I just took my plug out to see what it looked like and it was a tan color which means I am fine after I run it in the winter I will take a look at it again to make sure I am fine it started right up with the choke on and was a little hesitant but once it was warmed up it seemed fine plus the gas has been sitting for atleast a week or so.
ReconBayou
Oct 31, 2022 05:37 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
