ATV Disc
Old Feb 18, 2007 | 03:13 PM
poozer's Avatar
Default ATV Disc
Looking to buy a atv disc, I have a '07 Honda Rancher AT. Does anyone know if this machine will even pull a small disc? Or will it be to hard on the machine? I would like to put in small food plots, no more than 2 acres. Thank you for your time.
Old Feb 18, 2007 | 11:20 PM
ForemanDan's Avatar
Default ATV Disc
You can try, but it really was not much work. A regular Rancher would have done better.
I have to ask. Why did you choose a Rancher AT when the 420 Rancher has so much more going for it for less money?
Old Feb 19, 2007 | 01:57 PM
poozer's Avatar
Default ATV Disc
bought the AT because wife wanted auto,I didnt want to go bigger so the little ones can use it.I didnt know the AT was so guttless,should of done a little more homework before buying.I hadnt planned on using for light field work, but after buying I thought it be easier than hooking up the big equipment,for small food plots on the farm.
Old Feb 19, 2007 | 11:41 PM
ForemanDan's Avatar
Default ATV Disc
I have one and while I have had no problems with it (wife's) I would trade it for a 420 Rancher in a minute. The pushbutton shifting of an ES is just as easy to operate.
If the 400 had the same low range as the Rubicon, you would be fine for plowing.
shimanok2
Jan 29, 2016 07:37 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
Chris0007
Jul 20, 2000 07:55 PM
