2006 rancher es shifting problems when hitting brakes
Old Mar 8, 2007 | 09:26 PM
hemphog's Avatar
Default 2006 rancher es shifting problems when hitting brakes
I have a 2006 rancher 350 4X4 es and it flashes a code when I have the lights on and hit the brakes. It flashes 2 and when I shut it off and turn it back on, its does fine until I hit the brakes. What's wrong?
Old Mar 8, 2007 | 10:22 PM
mykool61679's Avatar
check the battery!
Old Mar 9, 2007 | 06:37 PM
hemphog's Avatar
What do you mean by check the battery? What should I check for? The battery is only 3 months old and so is the atv.
Old Mar 10, 2007 | 05:01 PM
hemphog's Avatar
I charged the battery up but it is still doing the same thing
Old Mar 10, 2007 | 06:29 PM
i know if there is not enough juice in the battery, it will cause the es system, to malfunction. does it do it when you use your headlights, or any other electrical functions? i dont have a code book tofind out what the two flashes mean. maybe some one who has one will chime in.my es is 1.5 years olds and it has been in water butt-deep, and even went under a few times and it works great. good luck!
Old Mar 10, 2007 | 07:14 PM
RedneckRandy's Avatar
Try here for the codes.
http://forums.atvconnection.com/mess...did/514012.cfm
and here also
http://forums.atvconnection.com/mess...did/514013.cfm
Randy
Old Mar 10, 2007 | 07:43 PM
hemphog's Avatar
thanks
hemphog's Avatar
thanks redneck randy
ROWALKER
Jun 15, 2015 05:38 PM
Steven Bandemer
Jun 9, 2015 08:50 PM
RedRancher
Jun 4, 2015 12:29 PM
winterwolf
ATC 3-Wheelers
Jun 3, 2015 07:34 PM
