400ex smoking
Old Mar 28, 2007 | 01:57 PM
dabrowat's Avatar
Default 400ex smoking
I knowticed it smokes white smoke right away from start up. It has a WB e series. Could the valve seals be the culprit because i knowticed it takes oil to. Or could it be the rings. Thanks
Old Mar 28, 2007 | 03:48 PM
Frantic's Avatar
ide check the rings, my 250 did that, and it was the rings.
Old Mar 28, 2007 | 04:24 PM
dabrowat's Avatar
But did it also take oil?
Old Mar 28, 2007 | 09:27 PM
ACFreerider's Avatar
It only smokes at startup? White smoke at start up wouldn't be anything to worry about. Are you sure it's not leaking oil from anywhere?
Old Mar 28, 2007 | 09:40 PM
dabrowat's Avatar
It smokes the whole time im riding. Im positive its not leaking oil.
Old Mar 28, 2007 | 09:45 PM
When it's warmed up and warm out to? Are you sure it's white smoke?
Old Mar 28, 2007 | 09:51 PM
dabrowat's Avatar
Im positive its white smoke. Ill check tommorow.
Old Mar 28, 2007 | 11:13 PM
cluby's Avatar
Let me guess you have a K&N air filter on this thing. Ya sounds like the rings are worn out and the intake valves a most likey shot also.
Old Mar 28, 2007 | 11:28 PM
dabrowat's Avatar
Yep, it has a K&N filter. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 29, 2007 | 08:16 AM
cluby's Avatar
How many times have you cleaned it? Did you know it says right on their web site that over 10 cleaning and it starts to loose it's filteration ablities. When you rebuild your 400 through that thing in the garbage. Go get a Uni or Twin Air.
I am fourwheeler tech for over 10 years and seen countless times where K&N's where the cause of engine failures. Mostly because people don't stay up on the maintince, they look good but are really dirty. The only people that really get the benift of using K&N's are races.
