loud noise comin from rear end on 01 rancher 4wd
Sounds can travel, so it is often hard to tell exactly where it comes from. I would put a crate under the middle of the frame so the rear end is off the ground, then shake everything on the back end real good and see what you can find. Might be a shock or shock mount, the swingarm, play in the hubs, play in the axle, etc.
