300ex questions
Old May 4, 2007 | 12:36 PM
scootergptx's Avatar
Supersock
Hired Gun!
Default 300ex questions
Don't see the year model on this. If it's an older one, you may want to check the fuel filter too.
Old May 4, 2007 | 12:38 PM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
Originally posted by: kush
Originally posted by: motox26
And you can run the p*ss out of it right now when it's cold?
It has plenty of fuel and everything?
Does it smoke at all?
yes,yes,no, and I'm going to check all the tubes..
Well this is quite odd.[img]i/expressions/face-icon-small-confused.gif[/img]
Is it getting really, really hot? If so, it could be losing compression and that is what causes the bog. I've seen em cool down and run again before.
Old May 4, 2007 | 12:39 PM
Supersock
Hired Gun!
It does sound just like a 2 stroke when it loses compression.
Old May 4, 2007 | 12:42 PM
kush's Avatar
aahh yes forgot to mention its a 1995 so its a 2 stroke, what does it mean whens its loosing compression? and the tubes are not clogged
Old May 4, 2007 | 12:47 PM
  #15
motox26's Avatar
Shed Knocker Rider
Harley Punk!
A 300ex is a 4 stroke. Are you sure it is a 300ex?
Losing compressing basically means your piston and rings are wore and when they won't hold compression, you have no power. The more compression, the more power. But coming out a dieing when hot is more common with 2-strokes, 4 stroke will usually run a long time even on low compression.
Old May 4, 2007 | 12:48 PM
  #16
kush's Avatar
hmm someone had told me its a 2 stroke but yea its a 300ex
Old May 4, 2007 | 12:53 PM
  #17
Supersock
Hired Gun!
Not really looking for clogs as much a sharp bends that would pinch the line.
If it is a 300ex it's a 4 stroke. Anyway you can post a picture of it? That might help too.
  #18
kush's Avatar
I don't know if this has anything to do with anything but when i pull a wheelie, gas comes out the bottom could that be something
pic 1
pic 2
pic 3
Old May 4, 2007 | 12:54 PM
  #19
motox26's Avatar
Shed Knocker Rider
Harley Punk!
If it's a 300ex, it's a 4-stroke.
Are you putting mixed gas in it? Usually that wouldn't hurt a 4-stroke anyways, but it could be fouling the plug.
  #20
motox26's Avatar
Shed Knocker Rider
Harley Punk!
No that is normal, that is your overflow.
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
