300ex Sluggish
Old May 21, 2007 | 09:17 PM
zettler450r's Avatar
Default 300ex Sluggish
I have a 01 300ex with exhaust and UNI Filter... I have been working to get it running after sitting for a year, needless to say the carb was gunked up with crap and I had to take it apart clean it from top to bottom. It now looks like new however it seems sluggish. I put the stock jetting back on however didnt have the factory settings so just guessed on the needle setting and fuel adjustment setting. NOW it will run however is a little sluggish, hesitates under full throttle and back fires on deceleration. WHAT ADJUSTMENTS DO YOU ALL RECCOMEND ?
Also I cant seem to get the idle just right... When its cold it idles good however once it starts running and gets hot it idles much to fast so I find my self adjusting the idle all the time to acomodate it . What is this ?
Thanks for the help....
Old May 22, 2007 | 12:42 AM
YZStomper's Avatar
i have the same set up on my 93 but i have aftermarkets jets, when i i first put the carb on it was in idle for a sec then it started reving like yours i found that the throttle cable was to tight so maybea you should look at that or your jets are to small.
COFatboy
May 2, 2020 12:06 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
Wiley wolf
Sep 7, 2015 08:32 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
