2004 honda trx400fg slipping problems
Old May 24, 2007 | 04:18 PM
rv's Avatar
rv
Default 2004 honda trx400fg slipping problems
I have an 04 honda trx 400 with an electric or auto transmission. Whenever I climb a hill or put any torque on it in 2 or 4 wheel the gears slip and it won't go. Just wondering if anyone else has had this problem?
Old May 25, 2007 | 03:35 PM
rv's Avatar
rv
does any one have info on taking this trany apart where to start looking for the problem which side of motor is it an easy thing ti fix ??? need help here dont know where to start with this machine need help soon want to go riding !!!!!!!!!!
Old May 28, 2007 | 05:05 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
So this is a Rancher 400 AT???? If so, it is a hydrodynamic trans powered by pistons pumping oil, and has no "gears". You don't want to tear into that transmission! I don't think Honda even services them...they just swap them out. But do get a service manual, and go throught the trouble shooting section and see what it says.
Search for an article on the Rubicon transmission....same basic mechanism.
Old May 29, 2007 | 01:03 AM
Gimpster's Avatar
First confirm oil level. The sound you may be hearing could be the oil pump cavatating from lack of oil. Once you have proper oil level, make sure the shift cable is adjusted properly.
I've seen cases where the slider that shifts the sub transmission (rear of the engine), binds inside the housing. This will not let it go into gear fully. You can tell if this is the case by unhooking the shift cable at the engine and trying to shift it manualy. If it shifts real hard, this is what is wrong, not engageing gears totally within the sub transmission. The slider shaft and housing can be removed an dcleaned with some fine emery for smooth operation.
As far as gears, there is one big gear on the output shaft inside of the sub transmission. This gear is slipped over splines on the shaft. It is driven off a gear on the end of the countershaft. Odd if it would happen, but a shift fork within the sub transmission gear assembly could be bent and not sliding some gear side mesh totally together. These gears are not back cut so if a fork is bent they could jump. Rare though
The only other splines that could be stripping could be on eather the front or rear drive shaft couplings. Also under the front cover the shaft that the front driveshaft slips over, is a short shaft going to splinnes which it slips over to the main driven shaft off the sub transmission.
If you have to get this deep into the problem, may I suggest a service manual ?
----- Gregg -----
neilbedwell
Nov 10, 2018 11:02 AM
Land_shark1
Jul 10, 2015 12:53 AM
'86 TRX125
Jun 6, 2015 07:43 PM
blaze_master
May 26, 2015 11:18 AM
lovinhonda
Jan 25, 2000 09:17 PM
