250x help please
Old Jun 10, 2007 | 05:46 PM
0400ex's Avatar
Default 250x help please
i just bought a 1987 250x and it ticks in the top end and burns oil like crazy what could be wrong thanks
Old Jun 10, 2007 | 10:25 PM
bombrider04's Avatar
Welcome to the forums...Well with an old quad like that I would say that you are going to need a rebuild on the top end...If it is smoking I would say oil is getting past the rings and hence the reason for the loss of oil...The noise on the top end could either be the valves ticking or the chain for the cam and crank...I would take the top end apart and inspect everything since it is old and I am sure it is due for a rebuild, so just take a look.
Old Jun 11, 2007 | 01:17 AM
Hondaman81's Avatar
I have a trx 250x 1991 and it had alot od problems. Most likely as it is an older atv you need a new timing chain. Probably some new valves too.I had to replace two of my valves cause it jumped time. so check the timing chain and see what happens
Old Jun 11, 2007 | 12:51 PM
0400ex's Avatar
thanks for the posts, i just had a new timing chain put in a month ago do you guys know were to get a cheap rebuild kit and valves, there on ebay and the rebuild is $200 same price for the valves thats pretty steep for used valves, thanks again for the posts
Old Jun 11, 2007 | 01:41 PM
Hondaman81's Avatar
go to bike bandit. cheap aftermarket parts
big_g_squared
Jun 28, 2015 04:17 PM
rockrider
Feb 20, 2001 02:51 AM
owen350x
Jul 30, 2000 01:58 AM
99_warrior_350
Jun 26, 2000 04:50 PM
YellaTerra
Mar 30, 2000 04:38 PM
