TRX 200 charging help
Old Oct 3, 2007 | 07:35 PM
raw527's Avatar
Default TRX 200 charging help
I have an 86 trx 200 4trax .The battery will not charge nor will any indicator lights work (reverse or neutral).
These lights will only work when the running lights are switched on.But these lights dim and flicker as you rev just up from idle.
Anyone have any ideas on what is wrong and how to fix it?
thanks everyone
Ray w
Old Oct 3, 2007 | 07:55 PM
AcadGuru's Avatar
It could be many things...
Start simple first.
Did you charge the battery initially before installing it?
I would check for loose wires, check the
Charging Coil and the Voltage regulator to start with.
Any good manual has testing procedures for these items.
Check the wiring out thoroughly,
most of the time that's what I find is messed up.
Old Oct 3, 2007 | 09:07 PM
raw527's Avatar
Hi I have checked all the wires and cleaned all terminals.Still has the same effect.Somone said there was A magnito type charging system on this machine.I personaly don't know ,I am very mechanicaly challenged.
where is All the charging components located.I had the starter off and made sure it worked by operating it with A 12 v battery.It engages and disengages well.
Thank you for your help
ray
ReconBayou
Oct 31, 2022 05:37 PM
speedbuff
13
Nov 11, 2020 10:16 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Jersey General
1) Engine problems..
Sep 13, 2015 01:05 PM
zPuls3
Sep 12, 2015 08:54 AM
