400 ex clutch problem ?
Old Oct 21, 2007 | 10:00 PM
hoytultratec's Avatar
Default 400 ex clutch problem ?
just picked up a 99 400 ex runs good only problem the clutch is super hard to pull in whats the problem ?
thanks for all responses.
hoyt
Old Oct 21, 2007 | 10:55 PM
95wolv's Avatar
Two possiblities: one, the cable is dry and crudded up, get a cable luber and shoot it full of a good cable lube, two,the former owner rebuilt the clutch and put in heavy duty springs. I picked up a 2000 440 ex, clutch was stiff as a board, lubed the cable good, got a lot better, it had the heavy springs in, and since the parking brake was blocked off, I removed the stock lever and switch, and put in an EZ pull lever, made a world of difference. Try one or both of these, or if you want to pull the side cover, if it has heavy springs, you can remove half of them,and alternate stock and heavy springs around the housing, this will give you more bite, and not be as hard to pull.
Old Oct 21, 2007 | 11:42 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
The 400EX cables are famous for getting hard to pull after a while. As I recall, new ones aren't all that expensive.
Old Oct 25, 2007 | 04:19 PM
03bansh33's Avatar
i had a 2002 and i had the same prob i bought a new cable but sold the wheeler b4 i put it on the cable that was on it looked fine but from what they say that might be the problem. if not it got to be the cluth springs.
skinnyr6
Aug 25, 2023 02:18 AM
clsharky
Jul 13, 2015 02:07 PM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
Wnthunting
Jul 9, 2015 03:02 PM
