Hello, noob here
Old Oct 28, 2007 | 08:20 PM
devil380's Avatar
Default Hello, noob here
I just got my first 4wheeler and I'm having problems getting it started. It sounds like it is turning over fine, just wont run. I put in a new plug, check everything to do with fuel delivery, which seems fine, and charged the battery. Every now and then it will backfire. I haven't checked to see if the new plug is fireing though. The guy I got it from said it needed a new piston and rings, but should'nt still run? Thanks to all who can help
Old Oct 28, 2007 | 08:42 PM
devil380's Avatar
I just checked, and I have spark
Old Oct 29, 2007 | 02:04 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Really dirty carb??? Are the air filter, air intake system ok???
Old Oct 29, 2007 | 08:23 AM
devil380's Avatar
carb looks clean, intake boot is good, but air filter was pretty dirty
Old Oct 29, 2007 | 11:56 AM
03bansh33's Avatar
check the timing roll the engine to tdc ''top dead center'' remove the cap on the3 side of the engine down by the crank and look and see if the T is visable in the window if not your out of time.
Old Oct 29, 2007 | 01:37 PM
devil380's Avatar
how do I find TDC? I can do it on my bike because I have a kick
Old Oct 29, 2007 | 02:26 PM
03bansh33's Avatar
there are 2 caps that u can remove in the side of the case down by the crank on the left side one is in the very center there is a nut in there and u can use it to turn the engine over. remove the spark plug to make it easier and the other cap when removed shows the timing marks. with the plug out use a very long screw driver and put it down in the engine threw the spark plug hole and use it to feel when the piston is at the very top.
if you have anymore ? just write back
Nondem
Feb 22, 2020 12:20 PM
mark23
Oct 1, 2015 09:57 AM
Jesse1983
Mar 31, 2008 12:12 PM
jam53142
Feb 1, 2008 01:29 AM
