rubicon stuck in gear
Old Nov 3, 2007 | 05:59 PM
BERMBASHER's Avatar
Default rubicon stuck in gear
friends rubicon is stuck in 5th gear, says that the D1,D2,and maby some other lights are flashing i cant remember, when in reverse it just does the famous chug,chug thing and wont go. any body have a clue on this? thanks.
Old Nov 3, 2007 | 08:23 PM
HondaMechanic's Avatar
You have to count the flashes ..
Old Nov 3, 2007 | 08:26 PM
BERMBASHER's Avatar
he says its two.
Old Nov 4, 2007 | 07:17 AM
Code #2 is vehicle speed sensor .. The location of the speed sensor depends on the year of the bike 2001-04 (no selectable 4wd) the speed sensor is on the rear left of the engine .. On 2005-08 (with selectable 4wd) the rear speed sensor is on the front differential monitoring the front driveshaft speed .. You should check the couplers for water and tightness , clean & grease with dielectric grease then test the bike again...
Old Nov 13, 2007 | 11:54 PM
corpselooter's Avatar
wtf the world has to move backwards im glad i grew up in the 80s just pull the rope and go no bs sensors and shi t
Polaris5
Aug 29, 2015 09:11 PM
heath legg
Jul 24, 2015 01:01 PM
micheleLeigh
Technical and How-To Articles
Jul 19, 2015 07:32 AM
ghost civic
Jul 15, 2015 10:48 PM
sara durrant
Jul 6, 2015 05:32 PM
