trx 400ex JE piston Adding power
Old Nov 6, 2007 | 06:00 PM
EVMAN's Avatar
Default trx 400ex JE piston Adding power
Does a JE 12:1 std 85mm high compression piston add power to a 06 400ex? And will it effect the reliability of it at all? Also am i able to make the std bore from 85mm to 91mm without doing anything else beside putting the piston in?
Old Nov 6, 2007 | 06:43 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
Yes it will add power. Yes it will probably effect reliability a little. No 91mm piston will not fit in a 85mm cylinder without getting it bored.
Reactant
Mar 30, 2022 02:08 AM
Ripinandtearin
1) Engine problems..
Dec 11, 2017 08:06 PM
metal249
Jul 28, 2015 09:35 AM
metal249
Jul 24, 2015 01:00 PM
black_thunder
Jul 22, 2015 06:01 PM
