replacing front sprocket
Old Nov 13, 2007 | 11:22 PM
ice820c's Avatar
Default replacing front sprocket
i will be ataking on this challenge. i have no master link in my chain. i was told that i can make one by grinding away at a pin in the chain( im guessing the head of it) and replace it with a master link. if not, what is the best way to change it wiothout breaking my chain. any other pointerts will help alot. thanks
Old Nov 14, 2007 | 10:21 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Not sure what you are saying???? You shouldn't need to break the chain just to change out the front sprocket. Maybe your chain is to long, and you don't have enough adjustment left so you need to shorten it....is that it??? Taking a link out shouldn't be a big deal, but you should get a proper chain tool (instead of grinding a pin).
On the other hand, if you are changing a sprocket, it is often a good idea to get a fresh chain and probably a new sprocket in back as well! Chains and sprockets are disposable items, and it is a good idea to change them out now and then anyway (your old X can probably use it!). The extra money you will spend, will save you from getting stranded out on the trail with a broken chain sometime......
Old Nov 20, 2007 | 10:54 PM
ice820c's Avatar
ok the front sprocket changhe was a succes. thanks. the only problem now i have is that the chain is too long for sure... its amazing what ONE tooth on my new sprocket can do. lol. so im gonna get a new chain. ythganks for the help
VRRRRT
Jun 27, 2015 09:38 AM
cornermike
Jun 3, 2015 07:27 AM
cornermike
May 27, 2015 10:04 PM
rhino99
Oct 2, 2000 02:44 PM
dosthoff
Jan 3, 2000 10:04 PM
