I WANT MY TOP END POWER BACK! ----400EX----
Old Nov 18, 2007 | 12:44 AM
Braaup's Avatar
Default I WANT MY TOP END POWER BACK! ----400EX----
I know I was going to loose it when I put it on but I didnt know I was going to loose as much as I did! I am extreamly happy w/ the sproket but I just want more top end.. I need items that will give it back.. (I cant have anything w/ the exhaust or motor done).. and thing bolt on.. I have have headers tho.. I am aloud to have anything that doesn't have to do w/ the motor or exhaust ( I am 13 and I have to listen to my father and I know how lame that sonds so no need to tell me..) So please, PLEASE... HELP ME!!!!
The Things I have on now that matter are:
1) K&N AIR FILTER
2) 12T SPROKET
I am getting a rev box for X-MAS (Dont know if that'll help any..)
<u>PLEASE HELP ME!!!
THANK YOU SOOO MUCH!!!!<u>
Old Nov 18, 2007 | 11:45 AM
DesertYFZ450's Avatar
get a different rear sproket, i might be wrong but i'm pretty sure going up in the rear will give you more top end. the rev box will give you about another 1000 rpms so it will help a little
Old Nov 18, 2007 | 11:48 AM
Braaup's Avatar
THANK YOU SOO MUCH!
Old Nov 18, 2007 | 12:11 PM
Scooter86's Avatar
Knows Old ATV Questions!
Without touching the motor/exhaust, you are going to have to gear it back up somehow. How many teeth did the sprocket you took off have? If it was a 14 then go to a 13 tooth or buy a 2-3 tooth smaller rear sprocket. Be forewarned though, if you replaced a 13 tooth, then dropping 3 teeth from the rear is going to put you right back where you started. Good luck.
Old Nov 18, 2007 | 12:17 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Hard to imagine you like the smaller sprocket. I put on some ITP Holeshot XCT's (23" front/22" rear) for some increased ground clearance. Figured to make up the difference in tire size I would gear down one tooth in front.....it was way to much! The EX wheelies easily anyway, and even with the big tires I could not keep the front end on the ground any time I stabbed the throtle.......
I would try to split the difference, like has been suggested by going a little smaller on the back sprocket. Or, go back to your oringinal front sprocket, and go a little larger in the rear.....that is what I ended up doing!
Old Nov 18, 2007 | 10:03 PM
Braaup's Avatar
Thanks so much! I'll do my best.. I might beable to get a Yosh if it sint too loud.. look for forums topic about this.. Thanks again!
Old Nov 18, 2007 | 10:09 PM
Braaup's Avatar
I can't go back to my origianal sproket cuz I had to cut the chain lol Say if the stock is: O mine is now:* soo much smaller it had to use a clip to stay on and I have swamp witches on so there a big larger bug not a hole ton.. when I buy holeshots I'll feel how big the diference really is lol.. Thanks for the advice tho!
nature violator
Jul 3, 2015 08:40 PM
TLC
Jun 21, 2015 10:02 AM
UPLou
Jun 7, 2015 09:42 AM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
