2003 Honda 400EX: UPGRADES/MODS
Old Nov 26, 2007 | 08:15 PM
Braaup's Avatar
Default 2003 Honda 400EX: UPGRADES/MODS
Any idea? I do not want to mess with the <u>exhaust</u> or <u>engine</u>!!
These are what I plan on getting:
    The items I have that would effect the preformace include:
      Any other suggesions would be <u>highly</u> appreciated!!
      <u>
      Thanks Sooo Much!!
      </u>
      --Braaup
      Old Nov 27, 2007 | 10:16 AM
      Koopa's Avatar
      Is addicted to 4 wheel'n!
      You don't want to mess with the exhaust but you plan on getting a header and tip????
      Old Nov 27, 2007 | 11:03 AM
      ctateusa1's Avatar
      as far as the sprocket I assume your talking about the front sprocket, since you have a 12t and are going to a 14t. What kind of performance are you looking to gain? Low end or top end?
      If you want low end stick with the 12t if you want top end go with a 13 or 14. the 13 would probably be easier on it.
      Dropping the size of the rear tires will raise your speed.
      Old Nov 27, 2007 | 03:20 PM
      Aaron426ex's Avatar
      if u drop the size of ur rear tires u will lose top speed and gain acceleration..... thats wat i would do as far as the tire situation..
      Old Nov 27, 2007 | 03:21 PM
      Aaron426ex's Avatar
      <div class="FTQUOTE"><begin quote>Originally posted by: Braaup
          <u>
          Thanks Sooo Much!!
          </u>
          --Braaup</end quote></div>
          y dont u wanna mess with the exhaust or motor???
          Old Nov 27, 2007 | 07:38 PM
          Braaup's Avatar
          <div class="FTQUOTE"><begin quote>Originally posted by: Aaron426ex
              <u>
              Thanks Sooo Much!!
              </u>
              y dont u wanna mess with the exhaust or motor???</end quote></div>
              Cuz i cant.. i am 13 and of course I have to listen to my fater.. UGH! and I know it sounds lame.. just 4get bout it..
              Old Nov 27, 2007 | 07:40 PM
              Braaup's Avatar
              The tip to make it deeper and about 2HP and the header for about 3-4HP plus -2DB
              Old Nov 27, 2007 | 07:41 PM
              Braaup's Avatar
              <div class="FTQUOTE"><begin quote>Originally posted by: ctateusa1
              Dropping the size of the rear tires will raise your speed.</end quote></div>
              I want a good equal.. not to much of eigher cuz I want lots of top but lots of bottom but I am finding that, that may be impossible..
              Old Nov 27, 2007 | 11:47 PM
              ctateusa1's Avatar
              without going into the motor or changing the exhaust I dont think you will add lots of top and bottom end at the same time.
              I think if you add the head pipe, and the exhaust tip you will be lucky to see 1-2 hp total but the problem is you will still have the stock restrictive muffler on it.
              I would go with the tires for the drop in top speed as aaron said for the added acceleration.
              Old Nov 28, 2007 | 02:22 AM
              Aaron426ex's Avatar
              w/e then.... just askin.. tryin to help for forget it...
