86 trx200 sx clutch staying engaged
Old Dec 11, 2007 | 09:59 PM
ripsaw0000's Avatar
Default 86 trx200 sx clutch staying engaged
I have a 86 trx200 sx fourtrax.I took it apart and put new clutch disc and springs in it.
I reinstalled all components, and now the centrifugal clutch is staying engaged.
While riding, when you come to a stop it keeps trying to pull and kills the motor.
Also when shifting from neutral to 1st, it will kill the motor.
I am running valvoline 10 w 40 motorcycle oil.
Anybody had problems like this?
I think there might be some sort of problems with the bearings inside the centrifugal clutch between the housing and the shoes. Nothing else makes sense.And it did look a little funny when installed
HELP, HELP, HELP
Old Dec 11, 2007 | 11:28 PM
Dennislinden's Avatar
? possible centrifugal clutch springs are weak causing lock-up does happen........Dennis
Old Dec 11, 2007 | 11:51 PM
ripsaw0000's Avatar
it didnt have this problem before I took it apart.
it was the opposite it slipped
the little roller bearing between the housing and the center part with the shoes
it didnt look right , maybe installed backwards or ?????
who knows
Old Dec 12, 2007 | 08:18 AM
HondaMechanic's Avatar
The sprag clutch is in backwards ..
Old Dec 12, 2007 | 09:28 AM
ripsaw0000's Avatar
whats that?
and
wheres that?
Old Dec 12, 2007 | 09:51 AM
Old Dec 12, 2007 | 10:28 AM
ripsaw0000's Avatar
one way clutch is the item I was trying to describe.
When I took it out a bunch of the litle metal pieces came out from the outside metal ring
one side has a lip or ring on it
which side goes in?
WilliamBos
Sep 6, 2015 10:53 AM
cdstang
Aug 31, 2015 07:52 AM
mbkirk
Aug 14, 2015 08:20 PM
mbkirk
Technical and How-To Articles
Aug 14, 2015 08:12 PM
ghost civic
Jul 15, 2015 10:48 PM
