01 rancher mods
Looking to hop up my 2001 Rancher 350ES. Looking for some input on what i should do. Trying to make a mod list, really want to get more out of my rancher. Need the biggest BANG for the buck. Thanks to ALL!!! O YEAH it is 4x4 if that changes anything lol.
get a warn 424 first off it will disconnect the front drive so that you can be in 2x4 mode and then switch back to 4x4
Then get a pipe filter and jet kit.
if you really want to dump some money into it you could do a big bore kit with a high compression piston.
Thanks ctateusa1, just got a few questions. With the warn 424 being in 2x4 will it give me more bottom end or is it just so i can go from 4x4 to 2x4? And on the pipe, filter and jet kit any suggestions on what brand? I know the air filter will be K&N unless you know of another you would suggest but the other two not really sure what the best is. Thanks again
the warn will just change it from 4x4 to 2x4 so that you can slide the back end around easier. pipe im not sure what or who makes one on the rancher, filter you will hear different opinions on this, either uni or K&N. Jet kit I would go with the dynojet.
HMF probably makes a good pipe for the rancher.
Thanks once again and yeah i was talking to a guy that i work with and he has a HMF pipe, dynojet jet kit, and K&N air filter and he said it done some good to his honda. So thanks for the info and all the help. I am going to get to work on my bike in a few days lol. Thanks again!!!!!!!!!!!
Sep 23, 2015 06:23 AM
