2001 Rubicon Gone Astray - ECM Blowing 30-amp fuses
Old Feb 12, 2008 | 03:59 PM
  #31
mwcormier's Avatar
Default 2001 Rubicon Gone Astray - ECM Blowing 30-amp fuses
Hello Gimpster, I'm having problems with my rubicon 2001. I'm having the same issues with the D1,D2, ESP, flashing on the display. I had a code 6, so I replaced the angle sensor. Everything seemed to be fine riding up and down the road. I took it with on a trip, and was about 5 miles into the ride when the display started flashing. The transmission seems to be in 1st gear, the gears will not shift. I'm also hearing a rattling noise around the engine, not sure what it is. I would appreciate your help.
Thank you
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
35dodge
Sep 29, 2015 09:40 AM
Lucas Bohanan
Sep 29, 2015 01:16 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
