Honda recon stalling help
Old Jan 4, 2008 | 04:39 PM
HondareconATV's Avatar
Default Honda recon stalling help
Hello I have a 04 honda recon manual 250. I have a problem. If i go up a long steady hill that bumpy it stays out just like it runs out of fuel. when I go to start it I have to choke it. If I pull a wheelie and set the front end down it will stall out like it runs out of fuel. I have to choke it to get it started.Besides that it runs fine. I removed the carb adn cheacked the float and needle,it was fine. Could it be the float vavle??
Old Jan 4, 2008 | 05:24 PM
I also noticed if I pick the front end up when idleing fuel will pour out of the overflow tube and it will stall.
Old Jan 4, 2008 | 07:16 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Float level may need adjusting.
Old Jan 4, 2008 | 07:36 PM
MadRebel's Avatar
I had a big bear years ago that was doing the same thing, float level needed adjusting.
Old Jan 5, 2008 | 12:47 AM
Honda Trx 450r's Avatar
i used to own a honda recon which did the same exact thing after i submerged it in water over the carb but all that i did was drain the carb bowl and put a new spark plug in and it ran like a champ once again.
Old Jan 5, 2008 | 02:25 AM
On this bike there not a float adjustment.I checked it with a ruler and it was in spec. It didn't stick etc kinda puzzled lol it runs out of fuel for sure I have to choke it to get it started after stalled.It's runs fine just doesn't like wheelies or hills lol/ I think it's the float vavle. I know some bikes you can adjust the float but I think the float vavle is kinda like the adjustment. I order one to give it a shot.
Old Feb 5, 2008 | 10:44 PM
brudnlaw's Avatar
well did it work. i have the same problem with my neighbor's recon and can't figure it out
Old Feb 7, 2008 | 07:12 PM
brudnlaw's Avatar
vent line
there is one vent line that goes from the left side of the carb under the tank and goes in to a hose holder on the steering stem in front of the gas tank. first try blowing through it, if no air or a small portion of air goes through it then pull it off and clean it out.mine was pluged up all the way, cleaned it and vala run like a new bike.
Old Feb 8, 2008 | 12:17 AM
Gimpster's Avatar
Every recon will drop fuel from the overflow when riding a wheelie
Make sure the baffle is in place around the main jet
The breather hose tip is a good one
Also, in some situations the side of the float valve may be worn enough to allow the float valve to wedge itself in the closed position. This may be what is happening on an incline
Also make sure the slow jet (pilot) is not restricted
----- Gregg -----
Old Sep 19, 2014 | 04:26 AM
recon.allen's Avatar
Default Thanks for the help
I was going out of my mind trying to figure it out.did all the obvious and basic things to no avail shure enough that line was clogged.....Thanks so much.
Allen...
Winchendon ma.
Originally Posted by brudnlaw
vent line
peytonius
Sep 28, 2015 02:18 PM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
Steeldon
Sep 8, 2015 10:51 AM
DGNAZ
Sep 5, 2015 09:14 PM
Hondamx751
Aug 13, 2015 01:06 AM
