420 battery
Old Jan 7, 2008 | 10:35 AM
wlvrn's Avatar
Default 420 battery
since i put on my snowplow, first year using it, my battery has died 3 times and i have had to jump start my rancher with my wifes recon. it seems since i have been using my winch more my battery cant handle the pressure. is there a good battery out there that can handle the pressure? or is my "alternater", i know i dont have an alternater i just can remember what its called that charges the battery, not doing its job?
Old Jan 7, 2008 | 10:56 AM
tramp's Avatar
Default 420 battery
My personel perferance is Interstate Batteries. However most any battery will suffice if maintained properly. In the winter when I am using my plow alot, I always hook up a battery minder after ever use and leave it on the bike till I use it again. If the battery has cell caps........check the water level at least once a month.
Old Jan 7, 2008 | 11:23 AM
wlvrn's Avatar
Default 420 battery
thanks tramp
Old Jan 7, 2008 | 11:52 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default 420 battery
Your generator output is 0.343 kW/5,000 rpm....which is very substantial.
I would suggest that because you are operating for long periods at low rpm and high drain, your generator isn't being given any chance to recharge your battery before you shut the engine off.
Like suggested above, put a battery minder on it every time!
Old Jan 7, 2008 | 12:29 PM
wlvrn's Avatar
Default 420 battery
where can i get a battery minder?
Old Jan 7, 2008 | 01:34 PM
hondabuster's Avatar
Default 420 battery
Battery Tender is the brand name of a good one, you can do a google search for the dealers near you, or mail order, denniskirk and rockymountainatv have them.
Old Jan 7, 2008 | 01:57 PM
wlvrn's Avatar
Default 420 battery
is the waterproof one any good from rockmountain?
Old Jan 7, 2008 | 02:03 PM
JeffinTD's Avatar
Default 420 battery
If you are talking about the Battery Tender brand water-proof one, yes it is very nice. If you are using it outdoors, that would be the one I'd get.
Old Jan 7, 2008 | 02:10 PM
wlvrn's Avatar
Default 420 battery
thanks guys.
pgamboa
Dec 24, 2023 11:52 AM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
