400ex reverse?
Old Jan 8, 2008 | 10:30 PM
brandonschultz's Avatar
Default 400ex reverse?
i'm looking into a new quad and want to know how you shift into reverse on the 400ex thanks
Old Jan 8, 2008 | 10:40 PM
sdm111's Avatar
2 strokes or 4
Put in neutral pull in clutch turn **** on r. front fender then shift down twice.
Old Jan 8, 2008 | 10:42 PM
so it's just like the z400 then?
Old Jan 8, 2008 | 10:58 PM
sdm111's Avatar
2 strokes or 4
don't know never had a z
Old Jan 8, 2008 | 11:26 PM
thanks
Old Jan 9, 2008 | 02:01 PM
deanz400's Avatar
No a Z you don't have to put in nuetral just pull in clutch and turn the **** then shift down
Old Jan 9, 2008 | 06:27 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
You don't need to put the 400ex in neutral either. You can shift into reverse from first gear.
After finished with reverse pull shifter up once and you are in first gear again.
Old Jan 9, 2008 | 07:45 PM
sdm111's Avatar
2 strokes or 4
When I bought my bike the salesman said that if shifted from first to reverse instead of neutral to reverse it can mess up the reverse spring or something like that so I am going by what I was told. They also said the same thing when I went to get the recalled spring replaced.
Old Jan 11, 2008 | 01:47 AM
ok but don't you still go from first to reverse i mean that is the shift pattern.
plus i just got an 05 400ex do you know where i can find a list of possible recalls?
anything helps
Old Jan 11, 2008 | 09:38 AM
sdm111's Avatar
2 strokes or 4
From neutral yes that's the shift pattern, once down first, once down again rev. I called my dealer and they ran the vin. to find out. It wasen't so I brought it to them they replaced the spring and gave me a paper to prove it in case I sold it. Mine is an 05' also. If it was bought new it probably hasen't been changed. As far as the neutral to rev. thing I'm just trying to save you the headache of having your bike stuck in rev.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
