06 honda rancher AT-Angle sensor set up procedure?
Old Jan 11, 2008 | 09:09 PM
SwampRancher's Avatar
Default 06 honda rancher AT-Angle sensor set up procedure?
what is the initial setting procedure after the sensor is relaced? how do u reset the computer?
Old Jan 12, 2008 | 01:46 AM
code 5 shows up then sometimes it will change to code 6, i bought the new angle sensor but now i have to reset the ecm do anybody have a service manual to tell me the procedures?, thanx!!
06 Honda Rancher 400AT, 2" lift, 26/12/12 mud lites rear, 26/10/12 mud lites front, ITP chrome rims, HMF slip on pipe, exhaust wrap, K&N filter, outwears prefilter wrap, Dyno jet kit, customized snorkle with differential and carb vent lines ran up with snorkle, 2000lbs superwinch, warn front bumber with warn trail lights
Old Jan 12, 2008 | 07:08 AM
HondaMechanic's Avatar
Did you pre-load the angle sensor when you installed it ..?..
Old Jan 12, 2008 | 01:50 PM
yea i preloaded the sensor, now im gonna go try these procedure wish me luck!
Old Jan 12, 2008 | 04:25 PM
ok well i got all the steps complete intil i get to where it has me press the throttle and after that step i cant get the "N" light to come on, dont know what im doing wrong....
Old Jan 13, 2008 | 01:44 AM
HeftyLefty's Avatar
Scroll to page 3 on the forum, read-'400 Rancher with GPS-thread.
Old Jan 13, 2008 | 08:12 AM
Try it again .. Holding both "up/down" buttons in ..Turn on the ignition.. As soon as you see the dash come on release the "up/down " switches and push up,down,up then wait a second and bleap the throttle from idle to full throttle twice ..
Old Jan 13, 2008 | 11:05 AM
Thanx guys i got it figured out now, on the throttle procedure its different then on here with the specs, within 5 secs after u see the "--" u hear the control motor cycle and while its still cycling through then u press the throttle and it will change to the constant "N"
Old May 7, 2018 | 04:28 PM
Robert Smith's Avatar
Default D
what in the hell is the Forum
Old May 17, 2018 | 02:02 PM
nagami's Avatar
this thread should be good
bigred20653
Aug 31, 2015 12:41 PM
400H0
10
Aug 20, 2015 07:34 PM
jldominic
Honda Side by Sides
Aug 8, 2015 06:54 PM
ltrmc02
Jul 22, 2015 04:50 AM
Scottma518
Jul 16, 2015 09:19 PM
