My 450 es won't shift
Old Jan 14, 2008 | 06:39 PM
jutt1's Avatar
Default My 450 es won't shift
I am just looking for ideas before i start spending money on my 450 honda. It will not shift electricly or manually. All I have is reverse and first gear.... Any ideas??
Old Jan 14, 2008 | 06:57 PM
BAIR's Avatar
My buddy just had the same sort of problem on his 350.
He could not shift into reverse. After two weeks of work he found a single wire off of a terminal - he replaced it - made sure it was tight and the problem was solved.
Now the problem is finding the wires to YOUR shift mechanism... his was buried deep in the tranny. Get a good electrical diagram and be patient.
Good Luck!
Old Jan 15, 2008 | 01:14 PM
jutt1's Avatar
Thanks man. Would that also stop it from shifting manually too?
Old Jan 15, 2008 | 03:41 PM
hondabuster's Avatar
Have you tried doing the honda rock? The tranny usually needs to be rotating, to shift reilably. Try gently rocking the quad for and aft, while trying the manual shifter.
Can the elec shift get you into 1st and reverse? or is it only manual lever that will do it?
Old Jan 15, 2008 | 04:03 PM
TLC's Avatar
TLC
My 2001 450 did that, it was along time ago but if remember right it was just a blown fuse or dirty conection at the fuse area under the seat.
95wolv
Sep 27, 2024 12:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
patrick.oc123
Sep 16, 2015 03:45 AM
BigCam
Sep 16, 2015 01:53 AM
patrick.oc123
Sep 15, 2015 02:45 PM
