300ex cylinder on 250x bottom end
Old Jan 18, 2008 | 04:47 PM
cronan22's Avatar
Default 300ex cylinder on 250x bottom end
i bought a stock 300 ex cylinder for my 1992 honda trx 250 x i was wondering if the cylinder would work with the same top end as in valves and cam and carb if i need different part what are they??
Old Jan 18, 2008 | 08:13 PM
juttin_15's Avatar
as long as the top end is bored, or you could buy a stock 300ex top end to put on the bottom end, the mount the same, i am pretty shore.
Old Jan 18, 2008 | 10:20 PM
95wolv's Avatar
As far as I know, the jugs are identical,the bore is exactly the same on the 250x and the 300ex, the only difference is the 300 has a longer stroke to give it the extra cc's.
Old Jan 20, 2008 | 05:51 PM
cronan22's Avatar
so the cyclinder displacment will remain the same unless i bore it out or if i stroke it
ReconBayou
Oct 31, 2022 05:37 PM
badgerboy1
Sep 26, 2017 06:11 PM
Beeline08
Nov 11, 2016 04:00 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
