84 big red 3 wheeler rear brake removal
Old Jan 19, 2008 | 08:53 PM
mcquay5's Avatar
Default 84 big red 3 wheeler rear brake removal
my rear brakes frooze up and I pushed the 3 wheeler back and forth to free them , now they do not spring back or work at all. I removed the brake cable and bolts from the rear brake cover and the 2 large nuts on the axle but cannot get the cover to come off , there seems to be a seal between the axle and cover that will not budge. I can rotate the cover but cannot get it to come off. does anyone know how to get it off or have some directions with pictures that they can send me. Please someone let me know. Thanks , Vic
Old Jan 20, 2008 | 07:27 AM
HondaMechanic's Avatar
Did you remove the o'ring when you removed the 2 big nuts & washer ..?
Old Jan 20, 2008 | 12:26 PM
mcquay5's Avatar
I did not do that , I will try that today, Is that all I need to do to access the brakes or is there more things I need to know. Your pics are great. Is there any chance that you could send me all the steps to rear brake change for this 3 wheeler ? My e-mail is mcquay5@yahoo.com. I would greatly appreciate it. Thanks again , vic
Old Jan 21, 2008 | 05:18 PM
mcquay5's Avatar
I took the o-ring off that is between the axle and the bearing and still no luck with getting it off , I can still rotate it though . but it will not budge as far as getting it to come off. Is the bearing pressed on or is there something else holding the brake cover from coming off ?? any help would be great
Old Jan 21, 2008 | 05:56 PM
The bearing is on a splined collar , the splined collar slides on the axle...
I emailed you the section from the 1984 ATC200 BigRed PDF shop manual ..
coldnorthpol
Jul 14, 2015 11:22 PM
tporath
Jul 11, 2015 12:31 PM
rcappie4
Jul 10, 2015 04:54 PM
Rider252
Jul 6, 2015 03:37 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
