new 400ex might be going back this is silly
Old Jan 20, 2008 | 04:30 PM
weider1717's Avatar
Default new 400ex might be going back this is silly
This sob is the hardest to get started cold I've ever seen. After it's warmed up and all it starts right up but cold u have to fully choke it then it's STILL hard as hell to get going.
a few min ago went out to ride again it has been sitting for a couple hrs so I try to start it with no choke on (ha good luck) so choke it and it tries a couple times now it won't hit a lick..flooded that easy???
hate to relate back to my 300 but my 300 could sit a month I would choke it for the intial start then back the choke off pretty fast then the rest of the day i wouldn't have to choke it and it would fire right up this one u have to choke each time on a cold start??? what a joke.
Old Jan 20, 2008 | 05:26 PM
hondabuster's Avatar
Summer should be different, but this time of year,I wouldnt be surprised to have to choke the motor, if it were cold to the touch.
The air box lid is on....correct? If its off, itll really lean it out.
You can go to a #40 pilot jet, like most of us have, and it makes the cold start and warm up much easier.
Try to not touch the thumb throttle til the motor fires on its own, because they can flood easily if you get carried away with the thumb.
Old Jan 20, 2008 | 05:48 PM
Doctorturbo's Avatar
GOT BOOST!
hondabuster does the 400 have a pumper carb from the factory?
Old Jan 20, 2008 | 06:51 PM
JeffinTD's Avatar
I also wouldn't be surprised if it has started to foul the plug. Short runs and cold temps with an engine that isn't broken in can do that.
Old Jan 20, 2008 | 06:57 PM
weider1717's Avatar
could be? I'm just not used to having to choke a atv to start it if i've already started it and brought it up to operating temp earlier that day.
my 300 would start first lick both of ours would after the first start of the day which was a pretty easy start itself.
could be they're just a cold natured engine compared to what i'm used to? after it's warmed it ofcourse it hits first lick but before that is more of a hassle than i'm used to.
Old Jan 20, 2008 | 07:43 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
It has a pumper carb, so hit the throtle several times before a cold start and it will inject raw gas.
Also, Honda jets lean to meet emissions standards so that is a factor, as well as the fact that the air is colder. If you are like most folks, you will be doing lots of mods and will need a rejet for those anyway....so I say just live with it until then.
Old Jan 20, 2008 | 10:51 PM
<div class="FTQUOTE"><begin quote>Originally posted by: Doctorturbo
hondabuster does the 400 have a pumper carb from the factory?</end quote></div>
Yep, and like reconranger said, the jetting on the idle circuit is a bit lean. Everyone who upgrades to a #40 pilot really likes the difference, its one of the cheapest and better mods for the 400.
Old Jan 20, 2008 | 11:02 PM
jrafter's Avatar
i rejetted to a 42 pilot and its still a b***h to start
they do not like the cold and i have to keep new plugs because they will foul a plug quick
Old Jan 20, 2008 | 11:18 PM
weider1717's Avatar
ok so this is normal for a 400ex....thats what I like to hear.
that FINE if it's normal but I was thinking maybe something was wrong with mine haha I was so pissed earlier I was ready to run a add in the paper and take a loss on it and go with something else.
Old Jan 20, 2008 | 11:45 PM
Red Rider
Sometimes just turning the throtle stop up a little (big **** on the left side), is all that it takes to keep it idling in the cold.
