400ex electrical problems
Old Jan 23, 2008 | 09:57 AM
billhilly's Avatar
Default 400ex electrical problems
my buddies 400 blows the fuse u can run all day if u dont turn it off it only does it when u turn the lights on replace the fuse and it is fine till u run with the lights on just curious where to start thanks
Old Jan 23, 2008 | 10:31 AM
Koopa's Avatar
Is addicted to 4 wheel'n!
welcome to the forums billhilly. I think that may be my old EX. Is it black?
Mine was the same way but, it was if you flipped to low beams. I replaced the whole headlight assembly with the pigtail and checked for all bare wires. From the pig tail of the head light assembly down the steering stem and around under the gas tank is where I'd check. That's where most bare wires seem to surface.
Old Jan 23, 2008 | 10:35 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
This is common with this model. The headlight wires can wear through their insulation. I just taped them all individually.
Old Jan 23, 2008 | 12:00 PM
billhilly's Avatar
thanks will check them
Old Jan 23, 2008 | 12:05 PM
Red Rider
On mine, the headlight wires were rubbing against one of the braces for the plastic. It was up front, very close to where the pigtail comes out of the back of the light.
skinnyr6
Aug 25, 2023 02:18 AM
Reactant
Mar 30, 2022 02:08 AM
Unzzy66
Jul 11, 2015 10:01 PM
ranvette
Jul 4, 2015 06:13 PM
yambam13
Jul 4, 2015 01:49 PM
