Oil pressure Test
Old Mar 3, 2008 | 02:26 PM
saby5757's Avatar
Default Oil pressure Test
I went to my local Honda dealership and was looking to get m oil pressure tested b/c my Rubicon isn't shifting. however, the few dealerships that I called say that it would take at minimum an hour, which cost between 60 to 65 bucks an hour. However, I can get a new pump for around 130.
So I was wondering if you can and if its been done: testing you own oil pressure. I know I need a special fitting to screw into the appropriate hole; however, I'm pretty sure its metric and I'm not sure where to find that part if I can even buy it.
Any feedback help!!
Thanks
saby5757
Old Mar 9, 2008 | 12:21 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Procedure will be in that all important to own service manual!
Old Mar 9, 2008 | 08:22 PM
HondaMechanic's Avatar
Yes you can check the oil pressure yourself .. If you have/have access to the right equpiment .. I have both the Honda gauge & fitting and a Fluke set-up .. The Fluke set-up is quite expensive , mine is a Fluke model 88 automotive (for the tach) .. Fluke model 863 graph meter & Fluke PV500 (for oil pressure) ...
The fitting is 10x1.25mm
As far as checking the oil pressure on a Rubicon , it takes approx. 3-5 minutes (if the bike is already warmed up) ..
Honda gauge
Fluke set-up
Joe454
Nov 20, 2020 01:19 PM
2many2ride
Sep 27, 2015 04:35 AM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
