06 Rubicon 500 front brake sudden loss
Old Mar 14, 2008 | 04:48 PM
action450s's Avatar
Default 06 Rubicon 500 front brake sudden loss
Its possible that a line has collapsed inside causing the problem, may not be noticeable on the outside. Other then that I'm stumped without seeing the bike myself.
Old Mar 14, 2008 | 04:56 PM
nedflanders's Avatar
ya, we wondered about line collapse too. it's about $50 to replace ALL the lines, including the metal line, and the brake hoses. but how do you check for that?
Old Mar 14, 2008 | 08:26 PM
LittleBill's Avatar
pump up the system once you have pressure, hold the handle in. the brake lever should stay solid for a long time. i have zip tied my brake level back when my parking brake failed. it held for the entire 2 hour ride home.
if it holds and then you turn the bars and you loose pressure, the line is cracked somewhere allowing air in
Old Mar 30, 2008 | 12:26 PM
we got our new parts and replaced the brake line from master cyclinder. also replaced the metal brake line. no difference. so we kept moving the handlebars back and forth. on extereme turn to the left, the brake lever would collapse. It turns out the RIGHT caliper would barely rub/brush the Riccochet a-arm guard on this extreme movement, causing the brake lever to collapse and total loss of front brakes. I have no idea how. We bent the a-arm guards so there was no rub, and now it works perfect. Poor design/engineering by Riccochet. same for Honda. If a little rub causes total front brake loss, that shouldn't happen!
Old Mar 30, 2008 | 12:46 PM
  #15
action450s's Avatar
Wow, strange problem, glad to hear you got it figured out, and thanks for posting a reply with the solution to the problem!!!
Old Mar 30, 2008 | 01:14 PM
  #16
Gimpster's Avatar
Thanks for info on the findings
----- Gimpster -----
Old Mar 30, 2008 | 06:13 PM
  #17
no problem. I can't stand it when people ask for help, the good folks here help them out with advice, and then the original poster never posts the final solution/outcome. aaarrgghhh!
Reactant
Mar 30, 2022 02:08 AM
greg74
Sep 10, 2019 03:03 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
Chocobamofo
Jul 10, 2015 07:46 PM
