Need Help-250x clutch
Old Apr 3, 2008 | 06:46 PM
  #21
dan92's Avatar
Default Need Help-250x clutch
ya i will get the springs also. thanks for the help i'll let you know if it fixes the problem.
Old Apr 3, 2008 | 07:04 PM
  #22
270quadsportguy's Avatar
Are u shure there is not one too many plates or friction disks? Theres no reason it dont work. Unless u are missing a washer behind the clutch basket, Can u turn the inner hub when the clutches are removed without the outer basket turning.
Old Apr 3, 2008 | 11:38 PM
  #23
dan92's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: 270quadsportguy
Are u shure there is not one too many plates or friction disks? Theres no reason it dont work. Unless u are missing a washer behind the clutch basket, Can u turn the inner hub when the clutches are removed without the outer basket turning.</end quote></div>
i'll check that tomarrow. if there is anything missing i still have the old motor to use parts off of that.
Old Apr 4, 2008 | 07:52 AM
  #24
HondaMechanic's Avatar
Old Apr 9, 2008 | 11:27 PM
  #25
dan92's Avatar
which one is the inner hub?
Old Apr 9, 2008 | 11:32 PM
  #26
dan92's Avatar
new clutch came today. i'll install it and see what happends.
Old Apr 10, 2008 | 11:42 PM
  #27
dan92's Avatar
what makes the clutch disengage. does the oil have something to do with that or is it just that clutch lifter on the inside of the case.
Old Apr 11, 2008 | 07:17 AM
  #28
This is hard to explane ..
Old Apr 16, 2008 | 01:57 PM
  #29
njcu's Avatar
Don't know if this helps or not but, if the bike is idling too fast I've noticed that it doesn't like to go into gear and feels stuck/jammed. Maybe tweaking the idle will do the trick. *shrug*
Old Apr 18, 2008 | 03:30 PM
  #30
dan92's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: njcu
Don't know if this helps or not but, if the bike is idling too fast I've noticed that it doesn't like to go into gear and feels stuck/jammed. Maybe tweaking the idle will do the trick. *shrug*</end quote></div>
it goes into gear fine it's just when i pull the clutch lever the clutch still grabs.
