rev limiter adjusters
Old Mar 23, 2008 | 08:17 PM
MIDZUKI's Avatar
Default rev limiter adjusters
i have a 400ex with a duncan full exhaust. i was thinkg of getting a cdi rev limiter pill wich raises the limit by 1000 rpm. anyone have expierence with these? can the bottom end of a stock 400 take the extra rpms?
Old Mar 24, 2008 | 12:35 AM
hondabuster's Avatar
If you look at the torque and horsepower curve of the 400ex motor, going an extra 1000 wont help a thing. The power drops way off after 7000 rpm, and by the time it hits the stock rev limiter, its down about 7 hp from peak. Unless you do some serious mods, and change the cam, the rev limiter wont help a thing. Changeing to the better pipe isnt enough. In fact, the aftermarket cdi usually arent as reliable as stock, and some even have hard starting issues, if the battery voltage drops too far.
The red line is a modified 416 motor, and the blue line is stock.
Old Mar 24, 2008 | 11:11 AM
jrafter's Avatar
im using an amr rexbox and i think it helped alot
Old Mar 24, 2008 | 11:52 AM
MIDZUKI's Avatar
Will the stock bottom end on a 400 motor hold the extra 1000 rpm. I plan to go with a bigger bore and higher comp. with the same stroke (stock crank).
Old Mar 26, 2008 | 02:23 AM
MIDZUKI's Avatar
no one knows? opinions?
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Whitelx1
Oct 2, 2015 10:55 PM
wrencher82
Sep 30, 2015 04:27 AM
r1pilot83
Sep 27, 2015 07:38 PM
