carb problem - 250x
Old Apr 2, 2008 | 11:24 PM
dan92's Avatar
Default carb problem - 250x
the carb is letting to much fuel into the motor and causing it to flood. i know there is something wrong with the carb cause i put a carb off of my other 250x and it strated right up. i'm thinking that it has something to do with the float. how can i fix this.
Old Apr 2, 2008 | 11:31 PM
dunkmaster06's Avatar
your best of just getting a new carb kit and putting all new stuff into it
Old Apr 2, 2008 | 11:53 PM
dan92's Avatar
ya i was thinking of doing that since it is only like $20. are the carbs the same from 87-92 cause the kit i looked at said it only fit 91-92?
Old Apr 3, 2008 | 04:52 AM
hondabuster's Avatar
The 91 92 uses a smaller main jet(122 vs 125), and a bigger pilot jet(38 vs 35)....than the other years of 250x. Thats all thats different in the kit. You can also use a 300ex kit, which is 125/38.
Id try to fix it with out using a kit. The float has a needle/seat which closes and opens to allow gas to enter the float bowl. Most likely this junction has a bit of grit or crud , which stops the closing. Start by just doing a good carb clean...remove the jets, and clean out the needle and seat area good. That should fix it..for free (except your labor)
Old Apr 3, 2008 | 03:10 PM
dan92's Avatar
ya i'll probably take it apart and clean it really good. thanks
big_g_squared
Jun 28, 2015 04:17 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
owen350x
Jul 30, 2000 01:58 AM
