Throttle Lever
Old Apr 19, 2008 | 02:31 PM
irishdreamsnd's Avatar
Default Throttle Lever
My throttle lever has to much play in it is there any way you can adjust it so that as soon as you hit the lever its ready to go because right now it moves about and inch before it starts gassing it up
Old Apr 19, 2008 | 03:12 PM
hondabuster's Avatar
On the back side of the thumb throttle housing should be a lock nut on a collar on the cable, take the free play out with that . Dont tighten it up so there is no free play, there needs to be some.
Old Apr 19, 2008 | 05:07 PM
thanks hondabuster just want to get alittle play out all my friends atvs dont have that much play in it thanks again
Old Apr 19, 2008 | 09:38 PM
KNOWSALOT's Avatar
The Facility
Check cable slack with the bars turned both directions before riding. I've seen dozens of ATVs have a mind of their own.
Fire up the engine in neautral, adjust a little and turn the bars. Some quads are affected by front suspension as well, so you can figure out the drill from there. Once you find the limit, back it off a bit and go ride. Forget factory specifications as they are only good when the unit is brand new even if you are using a brand new cable.
Old Apr 20, 2008 | 01:04 AM
trxguy9780's Avatar
well if you open up the throttle box deal, ubove the throttle lever there will be your throttle cable and you can adjust it just like your brake or clutch cables.
Old Apr 20, 2008 | 12:12 PM
I opened up the throttle box and i see that one nut and the cable coming thru but I dont understand how to tighten the cable up do I just tighten that nut up a little more and thats it are is there something else to do .I really dont want to mess with it till I know for sure
Old Apr 20, 2008 | 02:57 PM
trxguy9780's Avatar
well where the cable is come threw there should be a little adjuster. what kind of quad do you have?
Old Apr 20, 2008 | 03:03 PM
2000 350 rancher es 2x4
Old Apr 21, 2008 | 07:43 PM
trxguy9780's Avatar
if you cant see what iam talking about then its probly differant from my trx400
Old Apr 21, 2008 | 07:54 PM
okay
2quiker
Mar 22, 2022 08:36 PM
MeadowlarkFarm
Nov 27, 2019 08:40 PM
fordfaithful21
Dec 7, 2015 05:52 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
oliveiracarlos
Sep 7, 2015 03:39 AM
