help
Old May 12, 2008 | 12:40 PM
dustbucket23's Avatar
Default help
I need some help getting a axle out of 2000 honda 400ex on the rear so i can replace the bearings. what side do i need to take off so i can pull the axle thru?
Old May 12, 2008 | 12:47 PM
jrafter's Avatar
Default help
you take the right side apart and it will slide out the left side
Old May 12, 2008 | 01:09 PM
Default help
Do i need to break the two nuts apart that are side by side.
Old May 12, 2008 | 03:09 PM
jrafter's Avatar
Default help
yes and its a pain in the butt to do.......and dont use pipe wrenchs it really messes them up
Old May 12, 2008 | 03:42 PM
Androctus's Avatar
Default help
I used a big ole adjustable wrench. Didn't require the special wrenches that the clymer book suggests you need that cost 30 bucks a piece and you need two of them.... just an adjustable that will open to about 1 5/8" or more.
Old May 12, 2008 | 04:07 PM
Default help
Thanks
