Snorkel for Honda Foreman 450
Old May 18, 2008 | 03:16 PM
jrafter's Avatar
Default Snorkel for Honda Foreman 450
just take some pics from start to finsh.........and good ones of the airbox because thats why most people dont know how.....once you come out of the airbox its just plumping....gluing plastic pipe together...but dont glue untill you know it fits
Old May 18, 2008 | 04:23 PM
StrikeTheBox's Avatar
do you need any filters for the snorkel to restrict the airflow so it will run properly?
Old May 18, 2008 | 04:37 PM
jrafter's Avatar
no .......do you have any other mods airfilter pipe has it ever been jetted
here i website with lots of info
www.highlifter.com
do a search you will most anything you need
Old May 20, 2008 | 05:05 PM
action450s's Avatar
I used 1.5" ABS pipe. I started with a 5" piece comming out of the airbox where the stock unit was installed. The 1.5" pipe needs to be taken down with a lathe or a coarse file and patience to fit in the stock rubber fitting. Then I used 2 22-1/2 degree fittings to clear the engine and direct the pipe to the front fender. Then I used a series of 45's & 90's to get the pipe forward and up through the fender and through the rack. I used threaded couplers to make swapable snorkle heights like the triangle kit.
Pics on www.sledsooley.com on the Area51 page.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Sep 8, 2015 10:51 AM
DGNAZ
Sep 5, 2015 09:14 PM
