What size tires on YOUR 400ex??
Old 05-23-2008, 10:23 AM
fastfive0's Avatar
Default What size tires on YOUR 400ex??
I am mounting a new set of wheels on my 400 so i need new tires....what size are you guys running and what type of terrain do you ride with them?? What size would you buy if you could get a new set right now?
Old 05-26-2008, 09:55 PM
fastfive0's Avatar
ok i know that there is someone on here with a 400 ex LOL
Old 05-26-2008, 10:06 PM
GravelPit's Avatar
I have Maxxis Razr2's on my 450r, they work really well, hook up very nicely, and they're 6ply also, so they don't wear fast at all.
Old 05-26-2008, 10:34 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
ITP Holeshot XC, on ITP Baja rims. We ride desert, and I have tried a number of different tires over the years, but I keep coming back to the XC (or XCT if I want a little more ground clearance). Front: 22x7-10 (4-ply); Rear: 20x11-9 (6-ply).
http://www.itptires.com/sportatv/holeshot_xc.html
Old 05-26-2008, 10:58 PM
richard212's Avatar
maxxis razrs 22's up front and 20's rear and i ride every terrain sand, mud, georga red clay, dust, asphalt everything!!!
Old 05-26-2008, 11:02 PM
Scooter86's Avatar
Knows Old ATV Questions!
I don't have a 400EX, but unless you routinely run in the mud/ruts I would stick with the 20" rear and 21" fronts. Personally, I have been having real good luck with the plane jane Razrs. They hook up well in the goo and on hardpack. I don't think they slide quite as predictably as the true mx tires like Holeshot MXR's, but they are tough as nails. Anything along the Holeshot/Razr lines(plenty of knockoffs out there now) should work fine. I would steer clear of the mx tires unless you are racing though. They wear fast and are usually 2 or 4 ply max. That leaves them to puncture prone in my book.
Old 05-27-2008, 10:05 AM
Red Rider
<div class="FTQUOTE"><begin quote>Originally posted by: Scooter86
I don't have a 400EX, but unless you routinely run in the mud/ruts I would stick with the 20" rear and 21" fronts. .</end quote></div>
It's Yamaha that usually runs 21" fronts, where Honda runs 22". Smaller tires in front will quicken the steering, but sometimes make it so quick it gets squirley. Stick with 22" on your EX.
Old 05-27-2008, 11:23 AM
Scooter86's Avatar
Fine, stick with the stock 22" size fronts if you want. The only time I would swap out from stock tire size is smaller for MX, taller for riding in mud, deep ruts, or snow. Your quad is designed to have a good overall handling/ground clearance package with the stock size anyway. Oh, and if going from a 22" to a 21" front tire makes your quad to "squirrely" then throw a steering stabilizer on it. Actually, I am a firm believer in them anyways and would prefer not to run a sporty without a stab, regardless of tire size. I only run a stick stabilizer on my quad. I bet I have sold at least 6 of these this year alone, just letting someone take a quick spin on my quad around a rough track or trail. Then again, if you race WNYOA you really don't need one, lol.
Old 05-27-2008, 11:56 AM
Red Rider
I don't mean "squirley" in the sense that you get headshake or anything like that, I mean that it will tend to oversteer. I put the Standard Holeshot's (21" front/20" rear) on my 300EX once (and yes it did have a steering stabilizer), and it would want to loop out in a tight turn. Take it from someone who's been there!
Old 05-27-2008, 01:23 PM
fastfive0's Avatar
I was looking at the iRazr's or the Razr/Razr II's Do you think these will make good trail riding tires?
Quick Reply: What size tires on YOUR 400ex??
