Valve adjustment on Recon
Old Jan 26, 2001 | 07:36 PM
Hondapride's Avatar
Yeah I know thats what my dealer said but I always use 92 Octane gas. So it must be the valves.
I was also thinking that if you adjust the valves you might want to adjust the cam chain.
If you take the cover off on the motor you will see the cam chain and it should have a little dot on the top sprocket and another little dot on the engine above that cam chain dot.(these are the timing marks) if you line these two dots up you will be on the compression stroke
and thats when you know to adjust your valves. To turn the cam chain take the spark plug out(very important step) and rotate the engine by hand using the pull cord. Then when the timing marks are inline you can adjust the valves.
1998 Honda Recon, Sur Tracks mounted on Itp aluminum,UNI air filter
www.geocities.com/hondapride_98
Old Jan 28, 2001 | 07:21 PM
Hondapride's Avatar
How did the Valve adjustment go?????
Any problems
1998 Honda Recon, Sur Tracks on ITP aluminum, Uni air filter
Old Jan 28, 2001 | 08:53 PM
Ursus's Avatar
HeHeHe...
I wasn't aware that it was going to snow and then rain. It turned my workshop (the backyard) into a swampy mess so I am waiting for a drier day.
Old Jan 28, 2001 | 10:32 PM
Hondapride's Avatar
Thats alright dude no worries
Just dont forget to let me know Im curious
I would do it myself but my bike is up at the camp/cottage/shack whatever you want to call it.
1998 Honda Recon, Sur Tracks on ITP aluminum, UNI air filter
Old Feb 3, 2001 | 05:06 PM
  #15
Ursus's Avatar
Well I finally adjusted the valves. All in all it went pretty smooth. I found out you can remove the gas tank without taking off the front fender, but its rather awkward, esp the reassemble the fuel line was a major pain to get back on. My valves were about .005 inch out of spec or roughly double what they should have been. After the adjustment I was able to start out in 3rd gear from a dead stop and could hear no clacky sound. I also replaced the spark plug since it was so easy to get to at the time. It took a little over an hour, but a good deal of that was trying to figure out a good way to get those pesky plastic fastners off, and squeezing the fuel tank back into place.
donintennessee
Jan 8, 2021 12:40 PM
Hankey Pankey
May 1, 2018 01:33 PM
Hunter100us
Oct 7, 2015 11:46 PM
Hondamx751
Aug 13, 2015 01:06 AM
MNatv89
Jul 7, 2015 11:36 AM
