1985 250es stuck in reverse
Old Jun 2, 2008 | 10:33 PM
volksmike's Avatar
Default 1985 250es stuck in reverse
I just got a old 3 wheeler and I was getting used to it and now it won't shift out of reverse. I have tried to raise the shifter, lower the shifter. Wiggle, beat, slam, cuss. Just about every combo of the above. I adjusted the play and the it made no difference.
Any ideas?
Thanks for helping a newbee
Old Jun 2, 2008 | 10:55 PM
HondaMechanic's Avatar
I would check this gearshift arm .. Honda had a lot of them break and came out with an up-dated (thicker) arm ..
Old Jun 2, 2008 | 11:25 PM
volksmike's Avatar
Hopefully not to sound too stupid, but are there online manuals to show how to get to the arm. Somewhere, sombody welded the shift (foot pad) lever to the shaft. I'm guessing I will have to cut the weld and get the outside lever off to start.
thanks for the diagram, it helps to visualize what is in there.
Old Jun 3, 2008 | 07:49 AM
No online manuals I know of ... PM your email address and I will email you the section/s you need from the 1985-88 Honda ATC250ES PDF shop manual ..
Old Jun 3, 2008 | 10:35 AM
volksmike's Avatar
sent the pm, forgot e-mail... fee more stupid...
Old Jun 3, 2008 | 12:29 PM
OK I sent what you should need .. Post what you find out..
Old Jun 3, 2008 | 02:17 PM
volksmike's Avatar
looks pretty stright forward, I will have to cut the shift pedal off the shaft (PO welded it together)
there is a shift shaft on e-bay, I might be better off getting a non modified one. Plust at the part houses, they are not that expensive presuming they have it.
Thanks for the info, I'll let you know what I find.
Old Jun 5, 2008 | 05:07 PM
volksmike's Avatar
UPDATE:
Took the left side cover off. Found pieces of the gear shift arm. There was enough of it left (though spread apart) to make a new one. I put it all back together.....
And it still won't come out of reverse...
The lever does seem to be doing something, it makes the bike go into neutral. But no matter if I pull up or push down does it do anything else.
I have tried to shift while it is under power, and while it is coasting, even sitting still.
Ideas?
PS noticed when I was reviewing the manual pages you sent, I should have taken the right cover off and alinged the clutch arm. Do you suppose that might be it?
Old Jun 5, 2008 | 08:46 PM
I sent the clutch section .. Also the post that centers the spring used to work loose or even break off.. Be careful not to loose the little roller .. We remove the shifter shaft on any in for repair and VERY seldom does the clutch cover have to be removed , it should line up and slide right back in..
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
mrtidy
Feb 3, 2016 05:00 PM
r1pilot83
Sep 27, 2015 07:38 PM
Jackg17
Sep 26, 2015 09:30 PM
