starting problems
Old Jun 9, 2008 | 07:48 PM
vwhotti's Avatar
Default starting problems
I just bought a 2004 Honda recon and had issues with it shifting, but think I got them figured out. Now I am having issues with the starting...It was fine at first, but now you have to rock the bike as hard as you can to get the electric start to work, or pull the string. Already cleaned the ECM and cleaned off the corrosion on the battery. I am open to any suggestions as this is our first four-wheeler. THANKS!!
Old Jun 10, 2008 | 03:42 AM
kazuya's Avatar
I've had the same problem. Check and look for a loose connection on your starter. If it's not that, then possibly you have a defective ignition switch.
________________
"Autopartswarehouse.com Blog"
Old Jun 10, 2008 | 08:51 AM
vwhotti's Avatar
Thanks I will check that today and see where that gets me...
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
