is my motor running hot
Old Jun 16, 2008 | 07:18 PM
Matt1980's Avatar
Default is my motor running hot
pulled the dipstick out after a ride and had to use a towel because it was so hot and put the dipstick in the towel and the towel started smoking
Old Jun 17, 2008 | 12:21 AM
Blazer19's Avatar
What atv did that? If its getting that hot you are going to melt your bearings and seals. You either are working it too hard or you got a blockage in the oil passage that allows it to cool. I would drain and check to see if any particles in the oil or the filter.
Old Jun 17, 2008 | 01:07 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
What oil weight and what brand you running? Sometimes running a lighter oil that is more pumpable will improve cooling. On the other hand, light oils aren't going to stand up to the heat as well, unless it is a synthetic.
My most recent Honda purchase, the Rancher 420, specs 0W30 as a year round oil....go figure!
Old Jun 17, 2008 | 01:16 AM
Matt1980's Avatar
I have a 1999 300EX. I only rode it for a half an hour and it seems to always be this hot. I use 10W40 synthetic motorcycle amsoil.
Old Jun 17, 2008 | 10:39 AM
Matt1980's Avatar
so if their is a blockage what am i supposed to do
Old Jun 17, 2008 | 10:48 AM
Blazer19's Avatar
Check the oild 1st because if there is metal in it you will be looking for new engine soon. For the dip stick to have that much heat in it you may have already screwed something up.
Old Jun 17, 2008 | 02:11 PM
Matt1980's Avatar
the oil looks good so is my oil pump bad or what
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
Steven Bandemer
May 27, 2015 07:39 PM
JackOReilly
Dec 7, 1999 09:12 AM
