killswitch on trx450r
Old Jun 24, 2008 | 05:41 PM
kmaukamp's Avatar
Default killswitch on trx450r
anyone ever hooked up a killswitch to a 450r. i tried to hook up a pro design to mine and i ran the positive wire into the coil with the main coil wire from the plug. because that was the only way i could get it to work. but when i took off down the road on it if i would hit to high of an rpm or romp on it it would start to die until i let off of it. any suggestions
Old Jun 25, 2008 | 09:58 PM
TractorPacker's Avatar
Do you have a balloon?
I plugged one in to the small wire at the coil. It has a male/female plug, so I made a little jumper with the same and then plugged all in line. The second kill wire is grounded to the frame with the coil mounting bolt. This is on an 04 and been been there since 04.
Old Mar 15, 2009 | 07:36 PM
mxrider2637's Avatar
im not sure, but there was an article in an older atv rider magizine, you could look online
01ssls1
Sep 22, 2015 06:50 AM
Aug 5, 2015 02:10 AM
yambam13
Jul 4, 2015 01:49 PM
BritBoy
Oct 27, 2003 08:58 PM
CyberTrip2003
Sep 12, 2003 10:53 PM
