another shifting problem on rancher
Old Jun 25, 2008 | 07:17 AM
demo08's Avatar
Default another shifting problem on rancher
i have a 2006 400 fa rancher 4x4 im gettins a error code the n flashes 6 rimes i understand thart it might be a angle sensor problem. i removed it and looked at it but i think that might have been a mistake can someone tell me where i need to go to fix it
Old Jun 25, 2008 | 11:55 AM
kmaukamp's Avatar
best bet would be a dealer or mechanic that knows what they are doing
Old Jun 25, 2008 | 02:46 PM
HondaMechanic's Avatar
Code #6 is angle sensor "swash plate angle" that usually indicates a faulty angle sensor .. Did you remove the angle sensor
or just remove the wire coupler ..?.. If you removed the angle sensor did you pre-load it when you re-installed it..?
Old Jun 25, 2008 | 08:58 PM
demo08's Avatar
honda mechanic thanks i did the testing it failed on number 3 continuity i was using a fluke 87 which is a good meter. i also chaecked resistance and it was at 56ohms and stayed there when i more the sensor. how do you load it when i get another one thanks for all your help
Old Jun 25, 2008 | 10:45 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
RedRancher
Jul 10, 2015 06:36 PM
Scottma518
Jul 10, 2015 12:42 AM
sara durrant
Jul 6, 2015 05:32 PM
