300ex 04 raptor rear shock mounting
Old Jul 16, 2008 | 10:21 PM
kukerdan's Avatar
Default 300ex 04 raptor rear shock mounting
Ok, i bought an o4. .. I know i can mount it if i start hacking stuff up,
what i want to know is,
can it be mounted upside down/>
it looks like it would clear that way
Old Jul 17, 2008 | 11:35 AM
kukerdan's Avatar
Default 300ex 04 raptor rear shock mountain
any thoughts?
Old Jul 17, 2008 | 02:43 PM
95wolv's Avatar
You should have done a little more research before buying, only the 2001 Raptor shock will work, it was the only year with a remote resivior, there is no way the piggyback style will fit by the air box.
Old Jul 17, 2008 | 03:17 PM
kukerdan's Avatar
It looks like i can cut a few trivial things and it would fit,
Id rather not, I just want to know if anyone
has tried mounting these things upside down,
or if there is any reason why it would be a bad idea to mount upside down
Old Aug 7, 2008 | 04:55 PM
kukerdan's Avatar
bump
Old Aug 7, 2008 | 06:06 PM
95wolv's Avatar
Some shocks can be mounted any direction, but most fluid filled shocks need to be mounted right-side up, especially with a resivoir on the shock,won't work right and probably wreck or wear out the seals upside down.
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
07Redrider400
Jul 25, 2015 05:31 PM
black_thunder
Jul 22, 2015 06:01 PM
cSchwartz
Jul 9, 2015 02:40 PM
