TRX250EX Statistics
Old 10-25-2008, 04:20 PM
murox's Avatar
Default TRX250EX Statistics
Hmmm what exactly are airbox vents, I mean I can assume they are vents in the airbox [img]i/expressions/face-icon-small-smile.gif[/img] but how do I make them. I have the K&N in and have run it for probably 4 hours since then, is this bad that I am doing this without vents, or am I just restricting the potential it has?
Old 10-25-2008, 08:45 PM
steffen400ex's Avatar
no, the vent will just help it to get a little more air, but all you do it drill the size hole it tells you to do then just pop them in. I had a 250ex and your not going to get to much more power out of it.
Old 10-26-2008, 12:46 AM
murox's Avatar
Ic, where would I drill these holes, on the cover to the air filter box?
Old 10-26-2008, 10:26 AM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
Yes, drill the cover. You can get the vents at rockymountainatv.com
  #15
Old 10-28-2008, 09:15 PM
murox's Avatar
Well I got the exhaust today, installed the exhaust and jets. It's extremely loud, haven't put in the sound limiter or whatever it's called. But the reason I am posting here is because I believe the jets are flooding it or starving it. The main jet went from 95 to 100. The pilot idk what the change was atm but I will try and find out. Anyway it runs fine while the throttle is down, but can't idle for more than 2 seconds without cutting out. Can you tell whether or not the jets are overfilling or underfilling it.
*NOTE I ALSO HAVE A K&N AIR FILTER*
  #16
Old 10-28-2008, 09:35 PM
murox's Avatar
Update:
Just adjusted the idling speed to increase it and it seems to idle well, although I'd prefer it back to normal, so advice is still welcome!!
  #17
Old 10-30-2008, 12:39 AM
murox's Avatar
To continue my talk to myself :-P there is a noticeable power increase, for my tiny weight I find it far easier to hold wheelies. Anyway, I'm hoping that the jetting which may be off, isn't harming the engine at all. Fixing the stalling was just temporary, I want to get this thing to the ideal settings for throttle response and longevity. If anybody has any input/advice I could use anything sensible, b/c I'm a total noob with mechanics!
  #18
Old 10-30-2008, 03:01 PM
Y2daT's Avatar
im juist installing a 300ex motor in my 250 that should make it faster..when I had the 250x motor it was piped and jetted and I ran with no air box lid ...
  #19
Old 10-30-2008, 05:55 PM
murox's Avatar
Hmmm, I think I'll go over to my machine and take off the lid and try to run it, see what happens if I turn down the idling speed. Can this harm my atv at all or allow dirt/water into the airbox?
  #20
Old 10-30-2008, 06:06 PM
murox's Avatar
The results were good! Turned down the idle to below what it was stock and it runs, so I turned it to what I think it used to be as stock.
Quick Reply: TRX250EX Statistics
