Thiner oil for the winter???
Old Dec 2, 2008 | 09:06 AM
Y2daT's Avatar
Default Thiner oil for the winter???
nice educatoinal experiment...we could test this but place the containers out side ..then test them early in the morning
Old Dec 2, 2008 | 10:18 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
<div class="FTQUOTE"><begin quote>Originally posted by: danf69
It doesn't matter if you use 10W30 or 10W40......you're still using a 10W oil on the cold side. If you want thinner oil, try a 5W--. Personally I'd sitck with 10W40.</end quote></div>
This is a common misconception, and is completely incorrect!!!
If you look at an oil data chart, the Viscosity at 40 degrees C (cSt), is the best indication of how viscous an oil will be on a cold start! For example, for the Redline oil I run, the 10W30 has a cSt of 70, and the 10W40 is 93! That is a significant difference of 23!
http://www.redlineoil.com/pdf/4.pdf
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
shimanok2
Jan 29, 2016 07:37 PM
r1pilot83
Sep 27, 2015 07:38 PM
byronman
Sep 6, 2015 06:34 PM
Sep 1, 2015 01:45 AM
