Warn Winch
Old Dec 22, 2008 | 10:29 PM
Muddog450es's Avatar
Default Warn Winch
Looking for information on Where to place the switch, (not the one on the handle bar) I've got a Rincon 680 and it's a Warn winch Tryed under the seat but not enough room ? Thanks for your Help.
Old Dec 22, 2008 | 10:36 PM
cherokee99's Avatar
Default Warn Winch
do you mean a power relay between the battery and winch? or the switch on a cord you can use while standing back from your atv?
Old Dec 22, 2008 | 11:31 PM
Default Warn Winch
Thanks for looking Yes Imean the relay between battery and winch How important is it to keep under cover?
Old Dec 22, 2008 | 11:34 PM
DODGE57HEMI's Avatar
Mopar Man!
Default Warn Winch
If it is a fairly new warn (3 years old or so) they are water poof and I would reccomend placing it out in the open as it needs the outside air to help keep it cool under use!
Old Dec 23, 2008 | 12:21 AM
58n65's Avatar
Default Warn Winch
<div class="FTQUOTE"><begin quote>Originally posted by: Muddog450es
Thanks for looking Yes Imean the relay between battery and winch How important is it to keep under cover?</end quote></div>
I put my Warn winch on about a week or so ago and I put the relay in the compartment by the battery....although I have a 420 Rancher. I removed the plastic cover and mounted it directly to the metal bar that's inside the compartment.
58n65
Old Dec 23, 2008 | 12:51 AM
snorulz's Avatar
Default Warn Winch
i mounted mine to the roof of my rear tool box inside it, the winch does not get used much except in the winter and i don't think it will over heat when it is below freezing. I wanted to keep it enclosed. I bolted it right to the panel that the manual is supposed to go in.
Old Dec 23, 2008 | 04:26 AM
SpiritOne's Avatar
Default Warn Winch
You didn't give much in the way of specifics, so I guessed. Here are the 2008 Honda Rincon Warn 2500 install instructions.
It is a pdf format, just copy and past into your browser.
<a target=_blank class=ftalternatingbarlinklarge href="http://warn.iwebcat.com/imgVD/WAR/75000-74374A0_rs.pdf
">http://warn.iwebcat.com/imgVD/...-74374A0_rs.pdf
</a>
On page 3, it looks like they recommend mounting it in a similar spot to where I mounted the contacter box on my Rubicon. That is under the rear fender, mounted to the rear storage unit.
If I guessed wrong on the specifics, go here for more precise instructions...
http://warn.iwebcat.com/_Membe...18&hdnUK=4578&hdnSts=0
Old Dec 23, 2008 | 08:36 AM
JeffinTD's Avatar
Default Warn Winch
On the Rincon, on the back of the airbox is a popular place to mount the contactor.
Jeff Roper
Feb 1, 2022 11:48 AM
Johnny Mac
Aug 15, 2019 03:13 PM
panicmanic
Sep 28, 2015 12:59 PM
cboler9
Sep 24, 2015 08:35 PM
chewy78
Sep 8, 2015 10:37 AM
