will a 300ex carb fit on 250x
Old Jan 8, 2009 | 01:07 AM
wmtitan024's Avatar
Default will a 300ex carb fit on 250x
i have an 87 250x and i was wondering if a 300ex carb will fit it with same jettings and everything
Old Jan 8, 2009 | 01:18 AM
cherokee99's Avatar
they are so close in cc size i would guess yes. mabe dial down the pilot jet if it seems rich
Old Jan 8, 2009 | 02:25 AM
johnboy27's Avatar
should work they are both 29mm. 250x main jet 125,pilot for an 87 250x is 35....91-92 is 38....300ex main is 122 with a 38 pilot. so i would say put in on and see how it runs, you might need to jet you might not.
Old Jan 9, 2009 | 12:34 AM
wmtitan024's Avatar
i put the carb on today but didnt have to much time to mess around due to work but i start it and it dies. it wont stay on unless i keep giving it gas. when i start it i smell gas so its getting to much gas, should i jus turn the pilot needle up and see what happens or do u think i should get new jets for 250x.
Old Jan 9, 2009 | 04:19 PM
johnboy27's Avatar
to answer your question from your other thread you started just swapping the pilot screw does nothing, you need to swap out the pilot jet. while your in there might as well take out the 300ex 122 main jet and put the 250x's 125 in there.
Old Jan 9, 2009 | 04:34 PM
wmtitan024's Avatar
how do u change the pilot jet?
Old Jan 9, 2009 | 04:57 PM
wmtitan024's Avatar
better question on the pilot jet thing, where is it at, i can change it if i kno what to take apart
Old Jan 9, 2009 | 05:17 PM
johnboy27's Avatar
take the float bowl off you'll see the main jet its a hex jet that sticks out, the pilot is the one next to it but its down inside the carb body and has a slot for a screw driver. i take it you do not have a service manual so the next best thing is go to powersportspro.com and look at the parts fiche.
Old Jan 10, 2009 | 12:33 AM
wmtitan024's Avatar
thanks and i have a manual, it doesnt go in great detail with the carb
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
